123 Users Online (121 Members):
Forums >> Revit Building >> Technical Support >> Alarmed!
44 Posts No Rating |
I’ve been using Revit a few months now and until today it has been rock solid. Today I attempted to open a completed job, the normal status bar, maybe a short second one, and then splash is idle for a couple minutes and BAM Revit is no longer running? As far as I can tell, there no version or build changes. I don’t anticipate having to do further work on this file, but you never know on these things. This is ALARMING!
Sam
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
it is indeed!
first open Revit and before you open the file tick the Audit button, if that does not help,
go to help-->create support request and submit your file to Autodesk to have a look.
Good Luck ![Smile](/images/smiles/smile.gif)
Members: | 2017072 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
