22 Users Online (21 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Window & Door Schedule
Tue, Feb 28, 2012 at 1:35:33 PM | Window & Door Schedule
tectacoma
tectacoma Avatar
I created a door and window schedule resptively but it won't let me add or type any info in certain fields like "Material".
For the windows I need to write in for example "Vinyl". When I enter something I get the message "Enter a value or
formula starting with '='.
Drives me nuts, I use the the typal descriptions, everything is set to instance so it can be edited later.
Any suggestions?
Tue, Feb 28, 2012 at 1:59:37 PM | Window & Door Schedule
LIZARD2806
3.5 Stars: 7 Votes
Is "Material" a parameter you made?  Or is it attached to the family?  It almost seems as if it is looking for a number as opposed to text.  If you added it via "Add Parameter" in the schedule dialog, I would erase it and start again.  Make sure you choose "Add Parameter" (not "calculated value" and be sure to choose "Text" from the "Type of Parameter" drop down.  Let me know if that isn;t the issue.
**Using Revit Architecture 2009, 2011, and 2012**
Wed, Feb 29, 2012 at 11:46:31 AM | Window & Door Schedule
tectacoma
tectacoma Avatar
Hi LIZARD2806,
thx for the help...I just tried it on a different project and got the same issue...I went to Fields, edit...then I chose
"remarks" from the drop down menu...ADD...and I got the same problem...it won't let me type or write anything in.
Really strange...
Wed, Feb 29, 2012 at 12:23:01 PM | Window & Door Schedule
As lizard says, the field is a number field - not text.  Changing projects doesn't do anything for you.  Whoever created this field assigned it to numbers so you will have to edit the parameter or create a different one.
Lizard also asked if this was a family parameter or a project created schedule parameter.  It could be either.
Combining Door & Window Schedule; it WORKS!
Wed, Jan 20, 2016 at 10:15:28 AM
door in window schedule
Thu, Apr 29, 2010 at 7:47:41 AM
Trying to Schedule a door that lives in a Window Family
Thu, Jan 16, 2014 at 12:07:10 PM
Schedules. How do I avoid having a schedule row for every door, room & window?
Wed, Aug 15, 2012 at 7:24:44 AM
Window & door tag formatting
Tue, May 25, 2010 at 9:27:07 AM
Page generation time: 2.2099
