39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Window locations
Tue, Feb 28, 2012 at 9:10:09 AM | Window locations
archie456
3 Stars: 1 Votes
Hi,
I'm putting together a window schedule on a large complicated building.
In one area one of the external walls has a void in it and so for various reasons we have constructed it using two walls.
The problem is that this external wall has a louvre window in it, and the window schedule using the from / to room fields picks up the void space and not the room beyond.
Is there any way I can amend the louvre window to pick up the room beyond rather than the void space?
Thanks.
Tue, Feb 28, 2012 at 9:17:06 AM | Window locations
In the properties for one of the walls, turn off the room bounding switch.  Now that void space will be part of a room.
Tue, Feb 28, 2012 at 9:26:32 AM | Window locations
archie456
3 Stars: 1 Votes
But won't that affect the room area - i.e. the area schedule will show a higher value for that room?
Tue, Feb 28, 2012 at 9:45:22 AM | Window locations
Yes - it will.  If you don't want that then fix your walls.  Why did you use two in the first place?  Perhaps it should have been one - maybe a stacked wall?
Expediency is not always productive.  Especially with Revit.  It is usually better to do it right if you want all the bells and whistles to work.
Edited on: Tue, Feb 28, 2012 at 9:46:37 AM
Custom Locations for Sun Studies - RA2009
Wed, May 21, 2008 at 5:56:25 AM
Plan Region Layout
Fri, Jan 25, 2008 at 7:16:07 PM
Any problems with modifying installation file locations?
Tue, Mar 10, 2009 at 10:04:19 PM
Adding custom locations for sun studies
Wed, Feb 25, 2009 at 9:41:00 PM
window toubles
Mon, Aug 23, 2004 at 9:53:29 PM
Page generation time: 1.2181
