36 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit 2012 MEP pipe sizes
Fri, Feb 24, 2012 at 9:00:02 PM | Revit 2012 MEP pipe sizes
idraw38
I'm trying to created a DWV drawing. I have many plastic pipes sizes loaded in the mechanic settings including 1 1/2".
However, when I try to draw a pipe 1 1/2" is not available in the diameter ribbon or the properties pallet. What going on?
Carl
Tue, Mar 6, 2012 at 2:13:57 PM | Revit 2012 MEP pipe sizes
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
Carl,
Make sure that the plastic material is defined in the type properties of the pipe type. If it is and the 1.5" is still not showing, check out the project units (shortcut: UN) under the piping pull down check out the category for pipe size, it might be rounding to the nearest 1" may need to change that to 1/4".
hth
Ian
http://familyjewels.typepad.com/
Revit MEP 2012 - Transfer Pipe Size & Pipe Materials bug?
Fri, May 18, 2012 at 10:04:27 AM
Revit MEP Custom User Pipe Sizes Not Available When Drawing Pipes
Sun, Dec 18, 2016 at 8:51:17 PM
PIPE SIZES TROUBLE in MEP 2012
Fri, Sep 21, 2012 at 5:53:45 PM
Calculating Pipe Sizes
Thu, Jan 13, 2011 at 4:30:40 PM
Hide insulation in MEP 2012
Wed, Sep 5, 2012 at 3:39:14 AM
Page generation time: 17.1824
