81 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Model Lines in Family
Fri, Feb 24, 2012 at 2:05:55 PM | Model Lines in Family
dpbittiker
I am trying to break apart a parametric family wall panel using model lines. As the family changes size, i'd like to have the model lines adjust their spacing. I cant seem to lock the lines to a reference plane or dimension value? Any help? Thanks
Sat, Feb 25, 2012 at 5:32:08 AM | Model Lines in Family
4 Stars: 203 Votes
Just sketch your lines hover the ref. planes and lock the padlock (don't use the "Chain" tool but if you use the chain tool you'll need to use the "Align" tool to align and constrain the ML)
Take a look at my image
Edited on: Sat, Feb 25, 2012 at 5:32:45 AM
Symbolic Lines and Model Lines
Wed, Mar 22, 2006 at 12:52:17 PM
Can you convert model lines to detail lines?
Wed, Mar 31, 2010 at 12:45:23 PM
Generic Model Family - solid extrusion not hiding Symbolic lines below
Tue, Nov 8, 2011 at 7:57:48 PM
model lines blocked by model components
Fri, Mar 19, 2010 at 4:35:47 PM
Model Lines to Detail Lines???
Sun, Aug 31, 2008 at 9:24:50 PM
Page generation time: 1.6318
