119 Users Online (118 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Using Revit Structure to produce Steel Fabrication Drawings (shop drawings)
Fri, Feb 24, 2012 at 12:30:51 PM | Using Revit Structure to produce Steel Fabrication Drawings (shop drawings)
Pdoak
I am looking at a project for mezzanines, stairs, hand rails, and storage bin stands. I will need to provide fabrication/shop drawings for the steel fabricator. I'll be getting a RISA model from the structural engineer and possible a dwg, but I need to take that/those and provide the fabrication drawings. I'm considering using Revit: import the RISA model and create the fabrication drawings from Revit.
Does anyone have any:
1) suggestions2) warnings3)experience4) ???
Thank you! I also might consider building the model and converting to dwg to package the drawings. I also have AutoCAD structural detailing, but I have not used it with its features, so I'd be learning on the project and adding to an already taxing process.
Anyway, any insight/advice would be very helpful! Thank you!
-Phil-
Sun, Feb 24, 2013 at 1:00:00 PM | Using Revit Structure to produce Steel Fabrication Drawings (shop drawings)
Baz1984
Hi, ive uploaded a similar post to yours but am also a bit light of any answers.  Thinking of adopting revit for our specialist fabrication company mainly for estimating and fabrication purposes not to mention greater potential for winning jobs as more and more main contractors start to demand revit models.  Keep an eye on my post too, maybe you will get some answers there...Baz, UK.
Using Revit MEP to make ductwork shop drawings
Wed, Jun 15, 2011 at 9:52:02 PM
Glue lam fabrication drawings
Tue, May 29, 2012 at 11:22:36 AM
can revit create hvac fabrication drawings???? help!!!! revit MEP 2009
Fri, May 7, 2010 at 12:00:48 AM
Precast Concrete Shop Drawings
Fri, Apr 10, 2020 at 2:08:54 AM
Any luck with making Mechanical shop drawings from Revit?
Fri, Dec 17, 2010 at 11:37:04 AM
Page generation time: 2.7837
