23 Users Online (22 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> truncated autocad dwg
Fri, Feb 24, 2012 at 10:29:05 AM | truncated autocad dwg
michB
REvit 2012
I am getting this error message when inserting a cad link.
geometry in dwg file has extents greater than 1E9 in Autocad units.  Data exceeding that range will be truncated.
How can I fix this?
Fri, Feb 24, 2012 at 10:49:48 AM | truncated autocad dwg
Your CAD file is too large.  Usually the problem is origin but also if they linked in another file.  Best advice is to edit the CAD file using WBLOCK with a closer origin.
Fri, Feb 24, 2012 at 11:20:27 AM | truncated autocad dwg
michB
thank you-relocated 0,0 and wblocked.
.dwg import problem
Tue, Sep 6, 2011 at 7:48:54 AM
revit dwg into autocad
Tue, Apr 27, 2010 at 11:13:41 AM
having trouble creating a truncated cylinder
Wed, May 9, 2007 at 4:11:33 PM
AutoCAD DWG Blocks
Sun, May 9, 2010 at 10:43:13 AM
Sheet DWG exports appeat PINK in autocad
Wed, Apr 10, 2013 at 7:54:45 AM
Page generation time: 2.3149
