84 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Schedule Distorting on Sheet
Thu, Feb 23, 2012 at 3:01:53 PM | Schedule Distorting on Sheet
jpagliar
Hi all,
I'm pretty familiar with schedules, but I've never had this happen before. My room schedule looks normal until I put it on the sheet and it shrinks to almost nothing!
I posed a jpeg of the schedule on the sheet. Please help.
Thanks,
Jamie
Thu, Feb 23, 2012 at 3:05:24 PM | Schedule Distorting on Sheet
That is a real sheet - not a sheet scaled to fit the model in model space - right?  It appears that your sheet size is huge!
Thu, Feb 23, 2012 at 3:14:39 PM | Schedule Distorting on Sheet
jpagliar
The sheet size is 30"x42". The dwg is scaled at 1/8"
Thu, Feb 23, 2012 at 3:39:42 PM | Schedule Distorting on Sheet
jpagliar
The problem is within the settings of the specific schedule. When I place a door/window schedule on this sheet, they are working normally. I was messing around with the settings for the room schedule earlier today and I must have changed something that would make it act this way.
Thu, Feb 23, 2012 at 3:39:56 PM | Schedule Distorting on Sheet
Then you must have a corrupted Revit or file.
  1. I would close and restart Revit
  2. I would audit your file first and see if that fixes your problem.
  3. I would dete that sheet and create a new one.
  4. If the above doesn't correct the problem - then I might look at reloading the program.
Edited on: Thu, Feb 23, 2012 at 3:40:15 PM
Thu, Feb 23, 2012 at 3:53:12 PM | Schedule Distorting on Sheet
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I'm with WW, on this one. I think you made that sheet up on the model space. Show a full scale picture of the entire sheet. Or use the sheet that was supplied with Revit.
Thu, Feb 23, 2012 at 4:05:51 PM | Schedule Distorting on Sheet
jpagliar
Thanks
Thu, Feb 23, 2012 at 4:08:39 PM | Schedule Distorting on Sheet
jpagliar
If the sheet size was the problem then how would my other schedules look normal? Only the schedule that I was working on is doing this. I'm using the same sheets that I've been using for a while now and I didn't make it in model space.
I'll keep looking at the properties of the schedule.
Thanks for the advice,
Jamie
Schedule on sheet wont update [ 1 2 ]
Fri, Mar 1, 2024 at 10:28:26 PM
21
How to link a Revision Schedule on Title sheet with Title Block
Fri, Jan 11, 2013 at 7:26:26 AM
Schedule view on sheet - how to make background solid
Mon, Jul 21, 2014 at 5:56:50 AM
Revit Sheet Schedule/Title Block Family Tie In
Mon, Jun 23, 2014 at 9:47:21 AM
Revision Schedule
Thu, Sep 13, 2007 at 2:13:38 AM
Page generation time: 0.7173
