65 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Looking for a source for png images to create blue painted cmu rendered image
Wed, Feb 22, 2012 at 9:30:56 AM | Looking for a source for png images to create blue painted cmu rendered image
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
Basically, the cmu material in Revit is either white or grey.  I need to render a dark blue painted cmu wall.  Any suggestions on how to find or create that?  Thanks.
Wed, Feb 22, 2012 at 10:02:18 AM | Looking for a source for png images to create blue painted cmu rendered image
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
I did finally look further down in the material file and there was a masonry, blue glazed block wall image that will work in this case.  But what if my client wants another color wall?  Without a new png image file to insert, how do I do this?
Wed, Feb 22, 2012 at 10:15:27 AM | Looking for a source for png images to create blue painted cmu rendered image
Then you copy the jpg file and edit the color using a different program and create a new material in Revit for it.
Wed, Feb 22, 2012 at 11:10:50 AM | Looking for a source for png images to create blue painted cmu rendered image
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
another source for textures and color, www.cgtextures.com
Thu, Jun 7, 2012 at 7:01:54 PM | Looking for a source for png images to create blue painted cmu rendered image
SwinkCatherine
The downloaded black Corbusier Loungue renders white.  After changing the "crocodile" material (listed twice), it renders white.  What is wrong? (Chaise_Loungue_-_Le_Corbusier_-_with_parametric_oscillation_3304.rfa)
Border printed around .png inserted images
Mon, Aug 22, 2011 at 1:57:49 PM
painted cmu wall..
Thu, Nov 14, 2013 at 11:16:49 AM
Rendered Image Colour Problem
Thu, Jun 13, 2013 at 11:23:05 AM
Rendering Tab
Tue, Sep 9, 2008 at 3:05:16 PM
CMU in a cut section
Mon, May 25, 2009 at 12:50:44 PM
Page generation time: 1.8907
