15 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> 2011 creating mass
So I use create mass very rarely. What happened? I used to be able to build a timber truss out of one extrusion and now I need to use a combination of masses and voids? Is this easier in the long run? I had to get online to find out how to make all that stuff again.
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
Maybe use an in-place family with a single extrusion like you used to ?
I did but it is just not as easy as it used to be.
![3.5 Stars: 393 Votes](/images/stars_3.5.gif) |
Are you using conceptual mass rather than just an in-place family? I don't see any changes really in 12 in the in-place modeling.
Massing definitely changed. There is now a 'conceptual mass' (created externally from the mass template file, allowing parameters etc) , an 'in-place mass' and an 'in-place family'. They all have solid and void elements that resolve each other.
The in-place families (as well as external families) still use extrude, blend, revolve, sweep and sweep blend.
Massing uses 'create form' to convert 2d geometry into solid and void objects that can be further manipulated by face or by edge.
Conceptual Massing can take advantage of 'parameters' or variables because it is an external file that gets loaded into the project.
Hope this info helps . . .
Edited on: Wed, Feb 22, 2012 at 10:51:27 AM
Hmm, (dashes off to Revit) thanks,
Aaaaaand I'm back. In-place families are where it is at. Thanks everyone. I was using conceptual mass instead of in-place families. I feel like a dope.
Thanks again!
AAron
Autocad 2011 Solid To Revit 2011 Mass floor error |
Mon, Feb 28, 2011 at 7:20:10 AM
Sphere Mass - Changing the mass into a roof |
Tue, Apr 16, 2013 at 8:25:38 AM
the mass is no longer transparent in 2011? |
Sat, Oct 2, 2010 at 8:54:40 AM
Mass Floors not all showing up - some missing |
Wed, Apr 11, 2012 at 4:44:46 AM
how do a SWEEP mass and DONUT ,etc in revit 2011? |
Thu, Dec 9, 2010 at 1:21:36 PM
Members: | 2026030 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
