64 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Controlling Display setting per Discipline
Fri, Feb 17, 2012 at 9:28:08 AM | Controlling Display setting per Discipline
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
In the properties of a view, I can change the discipline of the view and that alters the way things are displayed. Can I get into these settings somewhere to alter the graphic display? I'm having an issue where a linked in model is showing up as halftone in all views and I think it may be set to this per the discipline. thanks.
Fri, Feb 17, 2012 at 12:16:51 PM | Controlling Display setting per Discipline
Manny
3.5 Stars: 6 Votes
have you check your visibility/graphic overrides - Revit links?
Fri, Feb 17, 2012 at 12:33:05 PM | Controlling Display setting per Discipline
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
thanks for the reply, yes I confirmed the settings in Visibility Graphics and the link is not set to halftone. the VG settings are view specific so what is really throwing me off is that the links appear halftone project wide. To complete the job, I just hit the "bind link' function to bring the elements directly into the model which worked fine but I'm still curious. I must have hit a setting somewhere along the way because I've used links many times before without this issue.
Masking Regions and Discipline
Wed, Oct 24, 2012 at 1:24:19 PM
RAC 2012 - Structural Section View shows as Wireframe vs. Hidden Line
Wed, Mar 7, 2012 at 1:50:32 PM
Section Mark Not appearing (i've checked the Hide scale...)
Wed, Jan 31, 2007 at 3:32:34 AM
Sub Discipline under Views?
Fri, Apr 17, 2009 at 2:21:22 PM
Discipline view settings
Thu, Sep 17, 2009 at 2:36:59 PM
Page generation time: 2.3125
