50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Window not cutting furred wall
Mon, Feb 13, 2012 at 6:55:19 PM | Window not cutting furred wall
JakeCWD
I have a basement with furred walls that up until today I have been able to join to my foundation wall and the window cuts through both walls. I opened it up this morning and they are no longer cutting through the furred walls. After playing around for about an hour I have been able to get 2 of the walls to cut, but cannot seem to get the other ones to work. Does anyone have any idea what might be going on?
Mon, Feb 13, 2012 at 11:39:47 PM | Window not cutting furred wall
Warchitect
4 Stars: 5 Votes
this glitch happens to me every once and a while. mostly when i try to place windows in a angled bay, where the wall joins are not 90 degrees...anyway, I have to usually remake the window cut. but you could do two things in my opinion.
1. use the opening from the window library, place in the furring matching your window size.
2. use the edit wall profile and cut openings into the furring manually.
Tue, Feb 14, 2012 at 8:14:37 AM | Window not cutting furred wall
Try simply joinig the two walls.  When one wall hosts an opening an another wall (like a furred wall) is placed against it, the opening will cut both walls after using the join tool.
Tue, Feb 14, 2012 at 12:44:23 PM | Window not cutting furred wall
Warchitect
4 Stars: 5 Votes
he does that. its a glitch that the opening disappears or the window does when you reload the project.
Tue, Feb 14, 2012 at 12:56:05 PM | Window not cutting furred wall
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Have you tried:
Unjoin the walls.
Delete the Window.
Join the Walls again.
Add the window back.
Q. Is this a custom window or OOTB ?
Edited on: Tue, Feb 14, 2012 at 12:57:00 PM
Window not cutting wall
Wed, Mar 2, 2016 at 3:34:29 PM
footing/foundation/window issue
Tue, Apr 6, 2010 at 4:21:33 PM
window not cutting joined roof
Mon, Mar 6, 2017 at 4:23:51 PM
Mon, Jan 10, 2011 at 6:44:00 AM
Floor Plan - Window Cutting Problem
Fri, Jan 7, 2011 at 4:17:00 PM
Page generation time: 1.4960
