68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Automatically-Updated Callout Text in Legend
Mon, Feb 13, 2012 at 10:21:00 AM | Automatically-Updated Callout Text in Legend
pwinter
I am looking for a way to insert an automatically-adjusted detail callout in a Legend.
ie:  "For ceiling insert, see detail:  xx/x-x.xx"
Does anyone know of a trick to get this desired result?  I'd like to do this so that I don't have to keep a list of the places where I've typed a particular detail into a text box, so that when the detail locaiton changes, it automatically changes with it.
Thanks!
Tue, Feb 28, 2012 at 11:38:07 AM | Automatically-Updated Callout Text in Legend
LIZARD2806
3.5 Stars: 7 Votes
THis would be a great addition for this and other reasons, however I have not seen or heard of a way for Revit to do this.  My recommendation for a workaround, and it isn;t a great one, is that you can make a "view schedule".  This can reference all your details in the drawings, and of course you can filter out any details not placed on a sheet and the type of detail/view.  Then in your note, you can say, "For ceiling insert, see detail "Ceiling Insert Detail*".  Crying* you would have to manually manage the name you type here to coorespond to the view name).  However, the sheet and drawing numbers would always be up to date.
Yep, it is a non standard workaround, but until Autodesk gets around to allowing text parameters that reference sheets, it's the best that I can offer.  Good luck.
**Using Revit Architecture 2009, 2011, and 2012**
Can Revit Families and Groups be updated automatically?
Fri, Nov 17, 2017 at 6:47:02 AM
Beam and Column callout text...
Sat, Jan 24, 2009 at 5:35:19 PM
Keynote Legend Not Showing Keynote Text
Fri, Sep 6, 2013 at 11:41:00 AM
12
Masking Text in callout
Tue, May 10, 2011 at 5:43:30 PM
Legend issue
Sun, Jan 3, 2010 at 8:03:09 AM
Page generation time: 3.0524
