115 Users Online (114 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> URGENT! Installing Revit 2012 on Windows 8 Dev. Preview
Wed, Feb 8, 2012 at 12:21:11 PM | URGENT! Installing Revit 2012 on Windows 8 Dev. Preview
hammer87
hammer87 Avatar
3 Stars: 4 Votes
Anyone get Revit Architecture 2012 to work on the windows 8 Dev. Preview? Would appreciate any assistance in regards in this matter.s
My Futurama Fan Fiction 'Hammer087' - http://futurama-madhouse.com.ar/fanfic/indexh.shtml#hammer087
Wed, Feb 8, 2012 at 12:31:10 PM | URGENT! Installing Revit 2012 on Windows 8 Dev. Preview
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
doesnt work, you'll have to wait
Thu, Mar 1, 2012 at 10:24:08 AM | URGENT! Installing Revit 2012 on Windows 8 Dev. Preview
malonso
Any update to this post with consumer preview?  My AIO wants to know!
Thu, Mar 1, 2012 at 10:36:35 AM | URGENT! Installing Revit 2012 on Windows 8 Dev. Preview
hammer87
hammer87 Avatar
3 Stars: 4 Votes
I was going to try installing the Windows 8 beta on an old dell laptop so i can test stuff over the weekend.
Thu, Mar 1, 2012 at 11:03:17 AM | URGENT! Installing Revit 2012 on Windows 8 Dev. Preview
malonso
I replaced my laptop with an iPad last year but am going to partition my 2TB drive and install on a partition.  Then, do a clean install of Autocad Arch 2012 and Revit 2012.  The plan is to run that for a while and maybe eventually migrate everything over to the new partition and get rid of the old if things run smoothly.  I heard no problems on Autocad but Revit not much info out there.  Although, when I did the initial "App" (all programs on windows 8 are called apps now) compatibility test, it checked revit and autocad as both being ok to work on Windows 8.  We'll see........please post your results.
As I mentioned, my new AIO is touchscreen and its kind of nice actually to sketch on it.  I use the same rubber tipped stylus that I use for my iPad.  2012 maybe the year for the PC.  The promise of Windows 8 seems pretty cool if you watched the presentation from Barcelona yesterday.  Same operating system on phone / tablet / laptop / PC all being able to share the same "apps" with storage in the cloud and shared selective storage between all devices.  COOOL.
Fri, Mar 2, 2012 at 8:28:42 AM | URGENT! Installing Revit 2012 on Windows 8 Dev. Preview
hammer87
hammer87 Avatar
3 Stars: 4 Votes
I see, well the problem I was having in the dev preview was that it basicly would not install, something to do with the .NET. As for tablets, I can see the potential as using them say out in field and having the ability to access your project from the cloud so that you can better explain the design intent to the contractor/client. But as an actual laptop replacement I have to disagree.
Fri, Mar 2, 2012 at 9:41:51 AM | URGENT! Installing Revit 2012 on Windows 8 Dev. Preview
malonso
Well.....worked for me with no issues.  Loaded up Revit Arch and ACAD Arch.
Sat, Mar 3, 2012 at 9:17:18 AM | URGENT! Installing Revit 2012 on Windows 8 Dev. Preview
hammer87
hammer87 Avatar
3 Stars: 4 Votes
Well that's good to know. How well does it run in 8?
Thu, Oct 25, 2012 at 4:29:45 PM | URGENT! Installing Revit 2012 on Windows 8 Dev. Preview
jeffburbank
Thought you might all like to know that Revit 2013 "one box" installs fine in Windows 8 as long as you install SP1&2.  Pre SP2 you will find that the green contextual modify tab doesnt update as you switch between tools, also if you click on a tool from one of the non-updating menus Revit will crash with a fatal error.
Cheers!
Problem installing Revit 2014
Sun, May 5, 2013 at 5:05:12 PM
Revit Architecture 2012 Compatibilty with Windows 10
Thu, Feb 14, 2019 at 4:59:13 AM
Re-installing Revit Architecture 2011
Tue, Dec 13, 2011 at 1:26:18 PM
URGENT!!!! WINDOWS NEEDED
Sat, Jun 20, 2009 at 6:39:01 AM
REVIT MEP 2012: Installation problem-Error 2343.Specified path is empty.
Fri, Apr 29, 2011 at 7:30:51 PM
Page generation time: 2.6806
