Forums >> Revit Building >> Technical Support >> Unhide Elements Revit Architecture 2012
13 Posts No Rating |
I have hidden elements in detail views that I would like to unhide. I am able to toggle "reveal hidden elements", select the wall, and click unhide element. However, it will not unhide. I have checked VG to see if the category is hidden and it is not. This is happening in various views and the main culprit seems to be stacked walls. Any help?
I have not seen this yet but I think I can understand why it may be. Stacked walls are really stacked individual wall types. As such, each "nested" wall can be picked and tagged according to it's own definition. If you have a cropped view, you may be only picking the "nested" wall. Did you try using the tab to see what your choices are? They might be the entire stack or just the individual "nested" wall and that might be the problem.
I got very excited by the prospect of this. It did allow me to tab through the different sections of the wall. I tried to unhide all of them, but still nothing...
136 Posts No Rating |
Have you checked your view range, maybe you have altered it since you hid the elements??
I know this might be a really obvious one but it catches me out quite alot.
For Architectural Services visit www.jrpcad.co.uk |
Thanks, but I did check that as well. It's very bizarre because it will show up as pink when I toggle the light bulb. Once I click on it and unhide the element, it remains pink. I thought I may be in need of a revit re-install, but tried another computer in the office and had the same problem.
Did you try un-croping the view to see if that allows you to then pick the stack?
Looks like I double posted somehow, sorry about that. I have tried uncropping the view as well and nothing changed.
unhide elements and categories |
Sun, Aug 29, 2010 at 9:36:40 PM
Unhiding all objects in a view |
Sat, Nov 9, 2013 at 8:52:50 PM
Revit 2008 Unhide Category - Wall Sweeps |
Mon, Aug 25, 2008 at 3:05:23 PM
Hidden Items |
Mon, Nov 18, 2013 at 2:05:49 PM
Revit Linked File Question: UNABLE to unhide linked contour in Site plan window |
Tue, Jul 10, 2012 at 3:42:09 PM
Members: | 2100800 | Objects: | 23171 | Forum Posts: | 152296 | Job Listings: | 3 |
