97 Users Online (94 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> dimensions
Tue, Feb 7, 2012 at 2:44:52 PM | dimensions
michB
Revit 2012
I would like to be able to change the tick mark size on the dimension.  Most are set to 3mm whether it be an arrow/dot/angled line.
I have adjusted the text however I need something smaller as the tick mark is huge in comparison.
Tue, Feb 7, 2012 at 2:55:27 PM | dimensions
3.5 Stars: 401 Votes
Look at the properties for your dimension.  The tick size is there.
Tue, Feb 7, 2012 at 2:57:55 PM | dimensions
michB
but not smaller than 3mm
Wed, Feb 8, 2012 at 1:04:12 PM | dimensions
michB
STILL HOPING FOR HELP ON THIS.....
The dimensions in a 1:20 plan look silly with the text small and the tick mark at 3mm.  Simplest thing but makes the plan look unprofessional.
Wed, Feb 8, 2012 at 1:24:19 PM | dimensions
It has been so long since we set up our dimensions, I had forgotten how.
Goto your addition settings pulldown and select arrowhaeds.  Now edit or create what you want.  When I changed ours to metric, I see our ticks are about 1.8 mm.
Wed, Feb 8, 2012 at 2:51:18 PM | dimensions
michB
brilliant-I love this program.
thank you
EQ Display in dimensions Revit 2009
Tue, Mar 23, 2010 at 3:28:36 PM
Isometric Dimensions in Drafting Views (details)
Fri, Sep 28, 2012 at 3:13:08 PM
Changing Dimensions
Mon, Feb 7, 2011 at 9:02:52 AM
Disappearing Dimensions
Mon, Aug 19, 2013 at 12:33:56 PM
temporary dimensions disappeared
Wed, Apr 25, 2012 at 10:37:51 AM
Page generation time: 0.3134
