52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Walls not showing up on section cuts
Tue, Feb 7, 2012 at 1:36:01 PM | Walls not showing up on section cuts
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I am currently working on a project that is being built using Revit Structure and Revit Architecture 2012.  In Revit structure when I cut a section through a wall it is only showing my beams, floors, foundations, roof etc but it will not show the wall.  The same section cut using Revit Architecture shows all of the components.  Is there something I am missing as to why the walls arent showing up when cut in Revit Structure?
Tue, Feb 7, 2012 at 1:42:50 PM | Walls not showing up on section cuts
Do you have the linked model walls on?
Do you have the box in VG checked to show categories from other desciplines? ... and walls are on there?
Tue, Feb 7, 2012 at 1:55:26 PM | Walls not showing up on section cuts
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
We are all working on the same model so there is nothing linked in.  Walls were turned on in the VG and also when I turned on "show catagories from other desciplines".  I can usually poke around and figure this stuff out but this one has me stumped.
Tue, Feb 7, 2012 at 2:18:34 PM | Walls not showing up on section cuts
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I noticed that if I change the wall type to structural and then a bearing wall it will then show up, however the wall that I am trying to change is a stacked wall and I do not get the option to change it to a structural.. can this not be done?
Tue, Feb 7, 2012 at 2:52:56 PM | Walls not showing up on section cuts
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Figured it out thanks!  Just had to change the section properties to show architectural and not structural.. its always the easy things that get ya!
Void extrusion not showing in section cut
Thu, Jun 12, 2014 at 12:36:07 PM
Multiple Section Cuts as duplicates
Thu, Dec 4, 2008 at 11:45:00 AM
Phases and Section Cuts
Thu, Mar 19, 2009 at 9:49:28 AM
Section Cut Fill Patterns Black
Thu, Dec 24, 2015 at 12:40:14 PM
Section Cuts
Mon, Nov 10, 2008 at 9:21:08 AM
Page generation time: 2.9055
