Forums >> Revit Building >> Technical Support >> Solution for my school project.
5 Posts No Rating |
Well.. I've been trying to create my shop for the school project.
But when I am now, about to put the celling to build the second floor, I realize that I can't view the 1st floor in 3D mode. What kind of presentation does Revit Building support? How should I deal with the celling?
Thanks again.
First, did you actually model the shop using walls etc?
What do you mean can�t see the first floor in 3D? is it modelled using floors?
Ceiling is not a floor. You will need to create your second floor regardless, then go to ceiling plan and draw your ceiling.
Are you a student by the way?
I hate to say it but RTFM,
I suggest you go through the Revit tutorial, so you�ll have some basic understanding of Revit� good luck
Post edited on 2005-12-13 19:53:47
5 Posts No Rating |
Thanks for you help...
Yes, I a student. But I'm not in the major. I tried to pratice with the tutorials but it's too long and I am kinda lost so...
mate,
the best thing is to do the tutorial, it might be long but it will give you a good base understanding, otherwise you will run around in circles and at the end drop Revit...
school boy or school girl with bag |
Mon, Apr 3, 2017 at 7:01:22 PM
Geo Dome for school project |
Mon, Feb 9, 2009 at 9:16:16 AM
School in Revit |
Mon, Oct 30, 2006 at 9:59:01 PM
sharing while at school |
Thu, Feb 18, 2010 at 4:32:26 PM
School competition, need ideas! |
Fri, Feb 3, 2012 at 6:45:52 PM
Members: | 2102364 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
