50 Users Online (49 Members):
Forums >> Revit Structure >> Technical Support >> Do you model columns through slabs?
5 Posts No Rating |
I have a colleague who models the top of structural columns to the underside of slabs & then starts the one on the next storey from structural slab level (SSL), So, If the slab is hidden in 3d view there is a gap between the columns.
Is this the best way to proceed? I’ve never done it, but wouldn’t the analytical model mess up?
What do others do?. As described or take the lower column up to SSL or the upper column down to the underside of slab?
Cheers
Dave F.
You model it like you build it.
![coreed Avatar](user_avatar/14568.jpg)
you should construct the columns the way the would be constructed in the field and create opening in the slab if needed. MILYBI (Model It Like You Build It)
Problem with intersections between slabs(with finish)and columns |
Fri, Dec 28, 2012 at 11:31:58 AM
Question re: Model Performance vs modeling habits [ 1 2 ] |
Fri, Jul 17, 2009 at 2:57:26 PM
20
How much detail should one put into a model? |
Mon, Jul 28, 2008 at 6:15:12 PM
Sloped slabs and spot elevations |
Thu, Mar 6, 2008 at 1:18:13 PM
Walls cutting slabs |
Fri, Jan 23, 2009 at 1:57:20 PM
Members: | 2022586 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
