Forums >> Revit Building >> Technical Support >> Repetitive element in a sweep?
6 Posts No Rating |
Hello all.....if you had to create a repetitive element...say on a parapet cap - like bolt heads every 18" or so on a steel plate....how would you go about doing it? See hand sktech attached for reference. in Revit Architecute 2012)
Could you create a sweep that include a modeled element that shows up every so often? How?
Or would you just make the cap sweep plain & then place small modeled bolts (or something that looks bolt-ish) where you want them to show up?
It would be nice if it was modeled into the cap, so it's "automatic"...but I can't figure out how to do it.
This kind of thing MUST show up in a roof plan and elevation so that their locations can be very accutactly dimensioned & then in turn constructed.....so it can't only be handled by showing a plan or section detail...it has to be the whole thing.
Any help would be greatly appreciated.
Thanks!
A sweep is a sweep....What you want is not a sweep but a family that has a sweep in it and a arrayed element. Too much to cover her. Search for arrays in families.
6 Posts No Rating |
Ok - a family that has a sweep AND an array in it. Ok...off to google I go.
Thanks!
If anybody has any other suggestions on how to accomplish this, please let me know.
A suggestion. Wall caps are best done in the project in one operation, then they will miter correctly at corners. A family will not miter in the corners. So if you then want bolts, use a family with just those in it.
6 Posts No Rating |
Awesome - more stuff to google - wall caps here I come.
So again, if anybody has any suggestions for wall caps & how to accomplish this, please let me know.
Thanks Mr. WWHub !!
FILE SIZE AND REPETITIVE ITEMS |
Mon, Apr 21, 2014 at 10:51:59 AM
Hosting a Sweep Mass element |
Mon, Aug 17, 2009 at 7:06:22 AM
Problem with wall sweep show on wrong sections |
Wed, Mar 22, 2006 at 5:37:32 AM
Multiple repetitive floors |
Wed, Jul 27, 2016 at 5:56:50 PM
13
Can You Flex a Sweep in Components |
Mon, Jun 3, 2013 at 2:09:23 PM
Members: | 2119408 | Objects: | 23205 | Forum Posts: | 152301 | Job Listings: | 3 |
