51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wall projection to underside of curved roof
Thu, Feb 2, 2012 at 5:09:03 PM | Wall projection to underside of curved roof
MongooseST1
MongooseST1 Avatar
I have created a curved roof ( barrel shaped) to go over my bow string trusses. I now want to project my interior walls up to the underside of that roof. How can I do that. It appeasr that all I can do is select projection top constraint to one of the levels above whcih projects the walls through the roof ( bad).
Thu, Feb 2, 2012 at 5:19:28 PM | Wall projection to underside of curved roof
MongooseST1
MongooseST1 Avatar
I found it. I am using 2012 Architecture REVIT and when clickin the wall I want to modify the bibbon bar illumintes the MODIFY WALL and using ATTACH TOP/BASE I am able to use the bottom of the roof as the top constraint
Curved Wall Under Stair and Edit Curved Wall Profile
Mon, Apr 19, 2010 at 5:06:40 AM
Curved Stair - Smooth Underside
Thu, May 3, 2007 at 9:54:55 AM
Stair has strange curved underside
Thu, Aug 31, 2017 at 9:16:25 AM
Attaching Curved walls to underside of Curved Stairs
Wed, Sep 12, 2012 at 12:43:47 PM
How to get wall to run to underside sofit/underside of slab
Fri, Jul 6, 2012 at 11:54:22 AM
Page generation time: 1.3724
