67 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Ramp / slab clean up at intersection
Tue, Dec 13, 2005 at 4:40:51 PM | Ramp / slab clean up at intersection
crispin
Has anyone managed to get a sloping slab or ramp of the same width as a floor slab to clean up / mitre at the intersection without resorting to creating other geometry to subtract / join to each? C
Tue, Dec 13, 2005 at 4:53:01 PM | RE: Ramp / slab clean up at intersection
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If they are both floors then just use join geometry and that should clean it up. If its a ramp then you won't be able to cleanup neatly as you cannot join anything to a ramp. Best result would be to place a floor slab edge where you want the slab/ramp to join to make them look as though they merge and then use the linework tool to remove excess linework. Otherwise its probably easiest with an in-place floor family. HTH.
Wed, Dec 14, 2005 at 10:23:18 PM | RE: Ramp / slab clean up at intersection
crispin
Join geometry didn't clean - is a one off so was easiest to do in place floor family. Thanks Mr Spot
Wed, Dec 14, 2005 at 11:28:47 PM | RE: Ramp / slab clean up at intersection
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
They need to be the same material for the linework to remove completely.
A ramp!
Thu, Jan 21, 2016 at 11:37:46 AM
Wall intersection issue
Thu, Nov 26, 2015 at 9:26:19 AM
Can you slope a ramp side to side?
Thu, Mar 4, 2010 at 10:12:18 AM
RAMP TAG FAMILY FOR RAMP NAME
Mon, May 9, 2016 at 6:49:10 AM
walls overlap but dont join.
Sat, Jul 30, 2016 at 5:13:59 PM
Page generation time: 1.2144
