83 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Linked File line weights
Wed, Feb 1, 2012 at 12:30:38 PM | Linked File line weights
swdebenport
5 Stars: 3 Votes
it seems that the lineweights of a linked file are showing rather than our line weights.  any sugestions.
I have overridden the line weight of in the v/g options under the rvt links to the same number we use and it is still really thick.  any way to override their actual line weights.
Wed, Feb 1, 2012 at 3:21:33 PM | Linked File line weights
gregroberson
gregroberson Avatar
CAN YOU POST YOUR 'VG' SETTINGS FOR THE REVIT LINKS?
Wed, Feb 1, 2012 at 3:27:45 PM | Linked File line weights
Are you linking their file by view?
Thu, Feb 2, 2012 at 8:05:46 AM | Linked File line weights
swdebenport
5 Stars: 3 Votes
we only link our files for the model not the view.  I have read some other forums and found that the best solution (unless someone has something better) is to open their file and transger our line weights into theirs.  This works, its just a bit annoying to have to do this everytime they send a new file.
Thu, Feb 2, 2012 at 8:37:23 AM | Linked File line weights
Linked files are controlled by your project's VG settings.  No need to alter anything in the linked model.  Read this topic in your HELP: Displaying a Linked Model by Host View
You can also display the linked model elements differently than the host model.  For that, read this topic in your HELP:  Using Custom Settings to Display Linked Models
Edited on: Thu, Feb 2, 2012 at 8:38:16 AM
Thu, Feb 2, 2012 at 10:11:29 AM | Linked File line weights
swdebenport
5 Stars: 3 Votes
We have changed the our line wieghts from the OOTB revit wieghts.  This is what is causing the issues.
example:  the actual line weight for #9 is .0180 in our file.  in theirs its is .2.  Theres is much larger.  just setting the VG to 9 does not work because it reads their file's weight for #9.  I could set it to a line weight number closer to ours (their #3 or so) but it would not match exaclty and it is easier (yet still annoying) to just overwrite their file before linking or reloading.  The same thing happens with materials.  We have our precast conc. set to have no cut pattern but theirs is set to have a concrete hatch.  it shows up as a concrete hatch.
again if there is an easier way let me know.
I looked into the Using Custom Settings to Display Linked Models in help and did not find anything on this specific issue.
Thu, Feb 2, 2012 at 1:08:01 PM | Linked File line weights
TKennedy
4 Stars: 7 Votes
I thought that was kind of odd, so I went ahead and tried it myself. I'll be damned, Revit operates exactly how you said it does. Bummer. Makes sense, but bummer.
It'll be a bit of work for you, but have you considered changing your linweights back to OOTB (or at least something close)? It'll defenitely be a hassle right now, but might be easier in the long run. I'm wondering how everyone else is handling your projects linked into theirs, since they are going to have the same problems you are having.
linked file line weights
Fri, Dec 5, 2008 at 3:34:11 PM
How to match .CTB line weights with Revit
Fri, Dec 5, 2008 at 4:11:56 PM
Linked File Line weight is way off
Tue, Aug 21, 2012 at 7:00:07 AM
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:39 AM
Revit Structure Questions Line Weights
Wed, Jan 16, 2013 at 3:33:33 PM
Page generation time: 2.4749
