77 Users Online (75 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Phasing - showing all phases in a view
Wed, Feb 1, 2012 at 9:06:21 AM | Phasing - showing all phases in a view
ChelesaTheRad
I am working on a project that will have existing construction, demolition, and new construction. The issue I am having is that in the properties window only allows me to show either existing or new construction, not both at the same time in the same view. We will be doing some renderings and I've noticed that when I render if a phase is inactive it wont render correctly. I am working in Revit Architecture 2012
Wed, Feb 1, 2012 at 9:13:14 AM | Phasing - showing all phases in a view
3.5 Stars: 395 Votes
If your view, phase properties is set to new and the phase filter is set to show all, then you will see everything.  But if the view phase is set to existing, then you will not see the new when show all is selected.
phasing
Fri, Oct 7, 2005 at 8:14:02 AM
Showing multiple phases in one viewport
Tue, Jun 16, 2009 at 8:02:56 PM
Phasing Setup
Tue, May 15, 2012 at 1:29:05 PM
12
is it possible to disable phasing Graphic Override on a view
Thu, Jun 8, 2017 at 3:34:46 PM
Phasing: creating 3 phases, filter out middle
Thu, Jan 22, 2015 at 9:02:29 AM
Page generation time: 1.7023
