44 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> How to subdivide the Building in Revit?
8 Posts No Rating |
I want to subdivide my Revit building model including its components in many segments. These segments will be carried out one after another in the reality. How can I do that without need to subdivide every component (walls, ceilings....) ?
Are you doing this for construction purpose? It sounds as though you are talking about phasing.. if you are this link may be useful
http://wikihelp.autodesk.com/Revit/enu/Community/Examples/Example_Project_to_Illustrate_Phasing
8 Posts No Rating |
thanks,
but i m not talking about phases. I have a Revit-Building- Model and I want to divide it in  cast concrete - zones).
It sounds like your looking for 4D BIM. Sequencing the portions of your model. You can do this in Revit but it does take extra work. I believe NavisWorks may do this better but we don't use it.
Search the web for 4D BIM to learn more about how others may be doing this.
8 Posts No Rating |
thanks a lot
Masses With Surface subdivide using adaptive component - keeping it speedy? |
Thu, Dec 20, 2012 at 1:48:13 PM
panel walls - getting walls to subdivide automatically with joints already in. |
Wed, Nov 24, 2010 at 6:22:27 PM
Moving a Building |
Wed, Apr 30, 2008 at 5:49:59 AM
Problem: How to cut building into landscape |
Fri, Apr 1, 2011 at 3:02:59 PM
WHY THE A.REVIT BUILDING GOES SOOO SLOW? |
Fri, May 4, 2007 at 2:43:19 AM
Members: | 2022396 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
