54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> 2d Line Based compnents - rotate hatch region for plan and section
Tue, Jan 31, 2012 at 8:44:03 AM | 2d Line Based compnents - rotate hatch region for plan and section
TimothyLiv
I have created my 2d line based component with the revit family...I used the Vertical lines for the look I needed in Plan Details,
Now i need to show the same component in Wall section but need the region to rotate with the component.
Thank you,
Timothy Livingston
Tue, Jan 31, 2012 at 9:28:28 AM | 2d Line Based compnents - rotate hatch region for plan and section
Sorry but your question is unclear.
I take it that this is a 2D detail component - correct?  If so, then you can use it in any view and rotate it as you choose.  If this component has a fill pattern in it, then you need to understand Revit fill patterns.   I suggest you read this topic "Fill Pattern Host Orientation" for drafting patterns.
If it is something else, then be more descriptive of your problem.
Plan Region not shwoing wall hatch??
Mon, Jan 14, 2008 at 12:03:30 PM
3-d hatch region
Mon, Aug 11, 2008 at 10:32:34 AM
Content hatch - rotate with component
Mon, Apr 11, 2011 at 10:22:42 PM
Masking region at section callout head.
Tue, Jul 30, 2013 at 1:43:27 PM
Using Region (hatch) in Multiple Views
Wed, Mar 14, 2012 at 8:41:06 AM
Page generation time: 2.7932
