43 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Problem with importing objects
Tue, Dec 13, 2005 at 2:33:16 PM | Problem with importing objects
maxpaynelhp
I found many good source of rfa files and I want to use them for the project. But somehow I can't load them into Revit BUilding.... I need help. THanks
Tue, Dec 13, 2005 at 4:59:38 PM | RE: Problem with importing objects
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Load family?? there isn't any more too it than that. After that its just a matter of placing the element. What objects are you having trouble with.
Tue, Dec 13, 2005 at 7:07:56 PM | RE: Problem with importing objects
maxpaynelhp
Oh sorry I screw up... I finally got it done. Thanks anyway But there is one thing I am wondering about: When I insert decals (from modelling) I select a picture but it dosn't show up on the 3-d view. I wonder why? Thanks
Wed, Dec 14, 2005 at 7:50:52 AM | RE: Problem with importing objects
jyothi
hi, Are you not able to see in rendred view? Decal will not be seen in shaded or hidden mode. it will look as box with cross or so. the actual piture will be seenn only when you render it. Regards,
HELP! importing 3D objects cant be exploded
Fri, Nov 10, 2006 at 10:48:20 AM
Importing DWG or DXF file objects
Wed, Jul 12, 2006 at 10:45:33 AM
Importing .3ds objects into revit OR a WORKAROUND??
Fri, Aug 7, 2009 at 10:23:20 AM
Importing .sat files to Revit - the ever infamous problem
Tue, Jan 22, 2013 at 6:47:01 AM
13
Creating Objects
Mon, Mar 8, 2010 at 9:24:53 AM
Page generation time: 1.4583
