Forums >> Revit Building >> Technical Support >> Revit to CorelDraw
57 Posts No Rating |
I have sketched a line drawing of a celtic cross with knotwork for use on a family member's headstone.
The family want to use the design, and the text layout I included, but the Monumental Masons have asked for the indicative pdf I sent them as a Word file! ?!
I assume this is because that is what they usually get.
I thought a vector based format would be more suitable as they use Corel Draw.
It is confusing, because I cannot deal doirectly with them, but through another family membe, who stated that a vector based file was not appropriate as they were using Corel...
If someone can advise of a suitable format Revit can write to, that Corel can read, I would very much appreciate it.
you stated that the monument manufacturer, would like a PDF, this is the most common file to transfer. Get PDFCreator, free. Then you use it like a printer. It will create PDF's and other types of files, very handy.
No, sorry, I worded that badly. The monummental Masons have a PDF I sent them, but they have asked for a Word file.
print to file |
Sun, Jun 11, 2006 at 1:57:07 AM
PHOTOSHOP DOWNLOAD |
Tue, Mar 3, 2009 at 10:09:42 PM
Column in a slope and modeling a bench |
Fri, May 4, 2012 at 12:33:57 PM
Revit for Construction Documents [ 1 2 ] |
Tue, Jan 24, 2012 at 10:57:38 AM
20
4D simulation in Revit? [ 1 2 ] |
Mon, Jan 17, 2011 at 11:27:39 AM
18
Members: | 2119384 | Objects: | 23205 | Forum Posts: | 152301 | Job Listings: | 3 |
