73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> Yes/No Parameter Formula to switch between Multiple Family Types
Sun, Jan 29, 2012 at 3:41:07 AM | Yes/No Parameter Formula to switch between Multiple Family Types
designimpressions
Original Thread:
"Hi,
I have created a door family with 3no. Options using Yes/No parameters to determine which option displays at any one time. Each Option is referenced to an 'Integer' parameter which I named "Choose Option". The Options are 1, 2 and 3. As an option is selected the the Yes/No box checks accordingly making so only that option visible. This is all working fine.
What I want to achieve is to limit the options to 1 - 3 or cause any numbers other than 1 - 3 to return a value of 1 or 3. To resolve this I created an additional Integer parameter and input the following formula: "if(Choose Option < 1, 1, if(Choose Option > 3, 3, Choose Option))". This works in controlling the parameter numbers e.g. if I select '0' the option returns to 1 or if I select '4' the option returns to 3. but this parameter is not connected to the original option so is working independently with no affect to the family.
Can anyone tell me how I would connect the parameter if at all possible or give me an alternative work around please. I have attached an image for refererence.
Thanks,
Peter"
Solution:
The following are three possible solutions:
A, Use an If Statement Formula
[Image Insert Failed]
B, Use a Less Than, greater Than Formula
C, Use a Less Than, Greater Than Formula with an Or Statement
Edited on: Sun, Jan 29, 2012 at 9:34:36 AM
Sun, Jan 29, 2012 at 3:41:52 AM | Yes/No Parameter Formula to switch between Multiple Family Types
designimpressions
I can't upload images to complete this Thread, I've tried Chrome, IE and Mozilla.
Edited on: Sun, Jan 29, 2012 at 4:01:44 AM
Family types - conditional statement
Mon, Apr 18, 2011 at 3:59:51 PM
One family parameter has formula one has none
Wed, Jun 25, 2014 at 1:05:55 PM
<Family Type> parameter can't be controlled by formula. What else can we do? [ 1 2 ]
Tue, Aug 27, 2013 at 3:53:54 AM
29
Grouping multiple families types with multiple options
Mon, Jun 11, 2012 at 3:50:20 PM
Referencing a Shared Parameter in a Family parameter formula.
Thu, Jan 29, 2015 at 1:26:25 PM
Page generation time: 1.4840
