75 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Options Bar Mess
Thu, Jan 26, 2012 at 9:12:18 AM | Options Bar Mess
ADDISONE
I have been fooling around with an architectual column family with parametric void sweeps. There has been a lot of trial and error; thus a lot of experimentation with commands. An very annoying problem has come up where my options bar is displaying my void sweep through the entire list of commands I took to make it. Right now it is something like this:
Sketch > Sweep > Sketch > Sketch > Sweep > Profile > Sketch > Profile > Sketch > Sweep > Profile > Void Sweep | Model Groups
It is filling up the entire screen and I have no clue how to make it go away. Even when starting over and making a new sweep, the options bar retains the whole list of commands. I have tried closing and re-opening revit; other than that I have no clue what to do. I am using Revit Architecture 2011.
Thu, Feb 23, 2012 at 9:53:05 AM | Options Bar Mess
jlights
3 Stars: 2 Votes
Try deleting the troublesome sweep, purging the project (be sure to only purge the sweep so you don't lose stuff you didn't mean to get rid of), sync, close. Then do an audit: navigate to the project from within Revit, and check the  Audit box when you have selected the file to open. I don't know if this will work but it's worth a try.
jlights
Thu, Feb 23, 2012 at 10:17:58 AM | Options Bar Mess
I have seen this one before where a user did not properly quit a function before starting another.  I believe it was because the user switched windows during a function and lost the menu to quit.  I'm sorry that I can't remember how we fixed it.
Thu, Feb 23, 2012 at 11:13:14 AM | Options Bar Mess
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16825244&linkID=9243099
Custom Options bar parameter
Mon, Aug 17, 2009 at 4:35:45 PM
Large Monitors and Options Bar "Skipping"
Thu, Apr 23, 2009 at 3:22:06 AM
Option Bar in 2010
Tue, Dec 8, 2009 at 6:36:29 AM
Options bar keyboard acces?
Wed, Nov 11, 2009 at 6:34:21 PM
walls move when selected
Mon, Sep 27, 2010 at 10:44:18 AM
Page generation time: 2.7638
