Forums >> Community >> Newbies >> Color Fill Legend
67 Posts No Rating |
Which is the proper answer to what a color fill legend can serve (only one of these is correct) - Rooms, Areas, or Spaces?
Many thanks
JLB
I go for rooms.
Motto: "No Post left behind" |
I would have to say Rooms also
Help says this...:
Color Fill Legend
Color schemes color rooms and areas in a floor plan or section view by values that you define. You can add a color fill legend to the colored view to identify what the colors represent.
Yes, rooms only. Unless an area is assigned a 'Room', color fill will not fill it automatically.
If this is a test question, then it is stupid and wrong since the Help says it is for rooms and areas.....and you can put a color fill legend on an area plan.....
Unfortunately tests are sometimes salted and peppered with stupid questions...:-)
Can I have all my areas on drawing but only few values on Color fill legend? |
Tue, Oct 30, 2018 at 7:32:27 AM
Color Fill Legend |
Fri, Mar 30, 2007 at 10:52:20 AM
Area Legend not showing |
Fri, Mar 14, 2014 at 1:00:18 PM
Color Fill Legend- only want to show one value |
Wed, Apr 22, 2015 at 7:11:50 AM
rotate color fill legend |
Mon, Sep 23, 2013 at 9:46:00 AM
Members: | 2100554 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
