93 Users Online (92 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Window Help
Tue, Dec 13, 2005 at 7:36:36 AM | Window Help
jstewart
This is a little hard to explain so see attached jpg. I need the window to cut just the brick wall back 2". How can I do this. It will not let me do a void and an opening in the window family. I would like to do it in the family becuase it needs to be on all the windows in my building and to use filled regions (like in jpg) would take forever! Thanks
Tue, Dec 13, 2005 at 11:22:25 AM | RE: Window Help
Rythmick
5 Stars: 2 Votes
Delete the cut opening then you will be able to create a void in the wall. You cannot have both a cut opening and a void in the family host (wall). Not sure why, it would be nice if we could. Post edited on 2005-12-13 12:23:37
Tue, Dec 13, 2005 at 8:00:24 PM | RE: Window Help
eldados
eldados Avatar
4.5 Stars: 8 Votes
yes it's the void and the opening, the reason you don't have both is so Revit won't get confused about which one to use... Smile
Integrator
KarelCAD
Wed, Dec 14, 2005 at 8:46:55 AM | RE: Window Help
jstewart
Thanks it worked perfectly. I just never thought to delete the opening and use a void.
Window sashes with different window numbers in the window schedule
Tue, Mar 19, 2024 at 11:49:54 AM
Window Legends-showing nested components
Thu, Mar 20, 2008 at 4:20:37 PM
LOOKING THROUGH THE WINDOW, SCHEDULE
Sun, Dec 19, 2004 at 7:03:40 PM
WINDOW FAMILIES
Thu, May 24, 2007 at 5:46:10 PM
Window's dimension don't show up in the window schedule
Fri, Aug 17, 2012 at 1:34:44 PM
Page generation time: 1.2065
