47 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Automatic extension of Beam
Tue, Jan 24, 2012 at 3:20:15 AM | Automatic extension of Beam
JSHARIEF
Problem-1 : (In Plan View) Two columns are separated by 30mm expansion joint. each column is connected to a beam perpendicular
expansion joint. When ever I'm drawing those beams (perpendicular to the expansion joint), each beam is extended to
other column, which removed the expansion joint between 2-columns. I try to split, redraw again but I fail. Anybody could
help, pleeeeeeeeeeeeeeeeaaaaaaaaaaase?
Problem-2: (In Plan View) Two "drop beams" & two "flat/hidden beams" are "meeting" or intersecting in a column, with
2- drop beams are perpendicular to each other. The same with 2-flat beams, i.e., 1-drop beam is align c/c with 1-flat
beam. When I draw the drop beam, it will automatically extended up to the edge of flat beam, creating short cantiliver
in the portion of flat beam. (note: I call a beam "drop beam" if the width is less than the height, while it is "flat/hidden
beam" if the width is more than its height. I use flat/hidden beam if slab system is with "hordi blocks".)
Again, I need help, pleeeeeeeeeeeeeeeeeeaaaaaaaaaaaaaaaaaase!
Tue, Jan 24, 2012 at 3:24:46 AM | Automatic extension of Beam
JSHARIEF
In problem-2: I need to remove the short cantiliver which i automatically created. Any body can help, please.
Automatic extension gate
Wed, Dec 26, 2012 at 11:56:03 AM
Stuctural beam extension visibility
Wed, Mar 7, 2007 at 5:27:12 PM
Automatic Beam System and Tag On Options
Wed, Nov 26, 2014 at 7:29:00 PM
Beam joint extension
Fri, Jun 18, 2010 at 12:42:56 AM
automatic number sequencing for beam marks
Mon, Feb 16, 2009 at 8:17:10 AM
Page generation time: 0.3193
