Forums >> Revit Building >> Technical Support >> Room Problem
Hey guys,
I had made this room bigger but now the room tool wont go to the full size of the room. I try to delete and redo but it
just does the same thing... No room seperation lines or anything.
http://screencast.com/t/jSoQ5qGCv
Revit 2018........ |
Is this room hosted on this level?
Cut a section through that bottom wall and post that with everything on.
No Design Options - right?
Basement wall doesn't cut this room and hidden in view - right?
Is there a wall below it? Can you show a section thru that room? It seems to me that there's an invisible wall or a wall above your cutting plane that defines the smaller area.
There is a wall below but not in the way...here are some pics..
http://screencast.com/t/VRCShFm5
http://screencast.com/t/artXbJrJcn
Think I found the problem if you look on this section you can see 2 little lines near the ceiling and near the ridge they are
exposed rafters I made out of a wall and just edited the profile. Any idea how to fix it besides delete the wall(rafter) looks
like it is cutting into the wall a bit tho
http://screencast.com/t/pvfJ1XvxxNop
http://screencast.com/t/32V6ip8yw
here is what the house looks like so you can see the exposed rafters.
It looks like you have not drawn-in the floors. If you don't have a floor, you will confuse Revit when defining the room.
Was that little feature wall thing. So all good Yeah I have to put the floor in client keeps changing there mind....always the way.
Thanks for your help guys if I didnt cut a section through there wouldnt of noticed
If that is the case you can always select the wall and uncheck "room bounding"
