46 Users Online (44 Members):
Forums >> Revit Structure >> Technical Support >> Revision Cloud Goof!
![Wildcat7 Avatar](user_avatar/38367.jpg)
20 Posts No Rating |
Was wondering if anyone has made this mistake ... in the sheet issues/revision box I forgot to uncheck the "Per Project" and check "Per Sheet" instead ... now I need to go back and fix the revision tag numbers. Has someone ever done this? How did you fix it?
I've tried by deleting all the revision clouds in the project, then going back to add the clouds per sheet mode ... but the revision tag don't show the number ... so I'm stuck! Any suggestions?
![gebber Avatar](user_avatar/50786.jpg)
![5 Stars: 4 Votes](/images/stars_5.gif) |
I'm not sure I fully understand the problem but if I'm correct you'd like to change the sheet / project information.
Go to;
Manage,
Project parameters,
Select the desired parameter and go to modify
Change the catagory,
Make you choice between Sheet and Project information,
If the parameter has to be sheetbased and you have to change it per sheet you can make a drawing schedule.
I find it easyer to change the information in the schedules.
Hope this info could be of any help.
You didn't need to delete anything. Simply pick the cloud and change its properties to the right revision.
Revision cloud closes revit |
Fri, Sep 28, 2012 at 10:47:52 AM
Hiding a Revision in the Revision Schedule |
Thu, Nov 21, 2013 at 3:04:51 PM
Revision Cloud graphics |
Mon, Aug 24, 2020 at 7:00:24 AM
Revision cloud |
Tue, Sep 2, 2008 at 9:35:26 AM
Revision Cloud |
Wed, Mar 7, 2012 at 9:25:48 AM
Members: | 2022391 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
