27 Users Online (26 Members):
Forums >> Revit Systems >> Technical Support >> Create '2' not statements in one formula
2 Posts No Rating |
Hi, i am tryign to figure out have to create a visibility of flow arrows...
YES/NO Check box --- Incline not(Decline) works
YES/NO Check box --- Decline works
YES/NO Check box ---- Both off (can't figure out)
is there a way to write formula creating not(Incline) and not (decline) ?
![4 Stars: 7 Votes](/images/stars_4.gif) |
I don't think your third condition is going to work because of the way you have the first condition set up. If I'm reading it correctly, you want to have both off, or one or the other (but not both) on. Use Incline2 instead of Incline to control the visibility of elements (see params1 for parameters and formulas). That's the simplest method.
If you want it to be a little more complicated, see params2. That has parameters for Incline, Decline and Both Off. Incline2 is on if Decline AND Both Off are unchecked, Decline2 is on if Decline is checked AND Both Off is unchecked. Use Incline2 and Decline2 to control element visibility.
2 Posts No Rating |
thanks that second parameter sheet worked. i knew there was some small thing i had screwed up! i used two not's in the formula instead of one.
''Visibility grafics'' and ''create parts'' problem when mak |
Fri, Mar 19, 2021 at 11:45:46 AM
Formula - 2 x 'if' conditions in one line? |
Thu, Dec 1, 2016 at 7:18:33 AM
Permanently unchecking the 'Editable Only' box |
Mon, Oct 27, 2008 at 11:39:20 PM
Okay. Fine. I'm a n00b. |
Tue, Apr 11, 2006 at 10:49:02 AM
Add ''scale'' on a drawing list, when it is not under ''available fiel |
Thu, Jan 12, 2012 at 8:35:32 AM
Members: | 2025963 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
