111 Users Online (111 Members):
Forums >> Revit Building >> Technical Support >> Color in Link Cad
2 Posts No Rating |
Hello,
i've created a model in AutoCad and now want to export it to Revit. While in AutoCad i've defined the color of the layer as beeing white, because that's the color i want my model to be.
In Revit, after linking the Cad and adding the rest of the project i'm developping, i made one render hoping that the cad part would be white. But instead it is grey and honestly i don't know how or where to manipulate it so it can be white as i want to.
Can anyone help please?
And one more question: Is it possible to add a material defined in Revit to a mass made in Cad and linked in Revit?
Many thanks for your attention and help.
Best regards,
Chi
When in revit go to the manage tab/additional settings/line styles and find the line type that you want to change the color of under the line color tab and force it to white. that will work if your cad import is exploded. If you are leaving it imported you can type "vv" to get to your visibility graphics overides, go to imported categories to find your import then you can override the line type that is in CAD.
Any CAD files linked into Revit must follow a careful process:
1- Bind XRefs: Xrefs can cause problems. Open the Xref dialog box and bind them all, preventing duplicate layers.
2- Run "Purge": This removes unused layers, linetypes, blocks, etc.
3- Run "Setbylayer": All lines settings should be set to layers, ignoring any color, linetype or lineweight overrides. Use the Setbylayer command to quickly resolve this problem.
4- Freeze Useless Layers: Freeze all layers not required in Revit.
5- Save A Copy: Keep the original DWG file just in case. Save the modified file in a Revit "CAD Links" subfolder.
LINKED CAD COLOR |
Mon, Mar 11, 2019 at 1:46:44 PM
Link CAD, Import CAD in the middle of space |
Tue, Sep 21, 2010 at 3:43:46 PM
CAD inserts appear in as many copies in my manage link view |
Fri, May 15, 2020 at 5:17:44 PM
Insert/Link CAD Advice |
Wed, Dec 21, 2011 at 2:56:22 PM
Link CAD |
Fri, Jul 27, 2018 at 9:28:46 AM
Members: | 2030582 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
