62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Add Parameter to Family Category - View Title
Tue, Jan 17, 2012 at 12:31:20 PM | Add Parameter to Family Category - View Title
devinmccarthy
I'm trying to create a custom view title family for the office (see attached). We'd like to have a label for Drawing Type (ie. "Building Plan" in the attached image) in the view title which would appear in the properties tab under identity data, next to the standard Title on Sheet, View Name, etc.
In the project, I am able to create a project parameter which appears as desired in the properties tab, but am unable to add the parameter inside the family when creating it. It seems impossible to add this parameter to the standard view title family template (alongside Detail Number, Sheet Number, etc.).
I tried it using a Generic Annotation family, but in the project, Revit does not recognize that family as a view category family and therefore you cannot choose this family when setting your view type.
Any ideas?
Thanks!
Tue, Jan 17, 2012 at 2:09:26 PM | Add Parameter to Family Category - View Title
TKennedy
4 Stars: 7 Votes
You will need to set up and use a shared parameter, not a project parameter.
Tue, Jan 17, 2012 at 2:18:56 PM | Add Parameter to Family Category - View Title
TKennedy,
I don't believe you can add any shared parameters to View Title families.....
Tue, Jan 17, 2012 at 2:28:49 PM | Add Parameter to Family Category - View Title
TKennedy
4 Stars: 7 Votes
I'll be damned, you're right. Sorry, I went and assumed stuff again.
Delete (title block) family category parameter
Thu, Aug 4, 2011 at 12:55:26 AM
adding a parameter to "view-title"?
Thu, Aug 2, 2007 at 4:11:25 PM
View Title Parameters
Wed, Nov 22, 2006 at 8:45:08 AM
new parameter to veiw title.rfa
Tue, Apr 7, 2009 at 11:26:04 AM
How do you share a parameter between several different sheets?
Thu, Nov 10, 2016 at 3:15:55 PM
Page generation time: 1.8184
