101 Users Online (100 Members):
Forums >> Revit Building >> Technical Support >> Text Wrapping in Door Schedule (in modify page, not when placed on sheet)
3 Posts No Rating |
Does anyone know of a way to enable text wrapping in the modify window of schedules?
Condition: I have a 'Comments' field at the end of my door schdule that I would like to leave as the last column. The text I type becomes obscured when longer than the width of the column. If I try to drag the column further to the right, I only have about a 1/4" of play. I have to go into the field editor, 'move up' the 'comments' field, then back in the modify window I can adjust the field to be as wide as I want it. But then I have to go back and 'move down' the field. Very annoying and time-consuming.
Yes, I understand that the schedule on the sheet wraps all on its own when you adjust the column width, however, my question concerns the "modify" window where I type the text. Any ideas?
Thanks!
![4 Stars: 7 Votes](/images/stars_4.gif) |
There is no text wrapping in schedule views. You can double click on the edge of a column (same place you would click and drag to resize) and it will stretch wide enough to display everything. I just tried it, and this does work on end columns. Clicking on a cell to the left of the end column and then tabbing over to the end column seems to help force the window to scroll to the right far enough to click on it.
3 Posts No Rating |
Very helpful. Thank you!
Revit Keynotes missing text |
Thu, Mar 5, 2015 at 1:11:31 PM
Door Schedule view on Sheet |
Mon, Aug 1, 2011 at 11:38:16 AM
Door schedule |
Sat, Nov 8, 2014 at 7:47:17 AM
Schedules formating |
Mon, Oct 27, 2014 at 1:09:20 PM
wall layer not wrapping for door family with jambs |
Tue, Sep 1, 2015 at 10:34:33 AM
Members: | 2017166 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
