97 Users Online (96 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Elevating curved walls
Tue, Jan 17, 2012 at 6:09:25 AM | Elevating curved walls
MDTSpace0
Is there a way of elevating a curved wall in Revit so that the elevation view can be stretched out to add dimensional details on to it? Because obvioulsy just creating a standard elevation of it produces an elevation with depth rather than it being flat?
Any help please....
Tue, Jan 17, 2012 at 8:30:11 AM | Elevating curved walls
This has been asked before and the answer is no.
Not sure how your stretched elevation is valid anyway.  In the field, how are they going to do that?  Flat dimensions don't work on a curve.  The only proper way to dimension these items is in a plan using radial dimensions or arc lengths.  They you can show what radial you are dimensioning to and then the builder can build it.
Of course if the builder can build the wall straight then roll it into an arc afterwards, then by all means, dimension it flat.
Question about elevating footings
Mon, Feb 1, 2010 at 2:31:35 PM
curved curtian walls
Mon, Nov 13, 2006 at 6:19:28 AM
curved surface
Tue, Nov 6, 2018 at 7:03:42 AM
Sloping curved walls?
Thu, Apr 20, 2006 at 10:09:16 AM
Attaching Curved walls to underside of Curved Stairs
Wed, Sep 12, 2012 at 12:43:47 PM
Page generation time: 0.6619
