Forums >> Community >> Newbies >> Hide Walls Below - New to Revit
I've searched through past threads and haven't been able to find a solution to the problem I'm having. I'm modeling the existing conditions of a two story building using Revit 2011...I completed modeling the basement/foundation plan and moved on to the first floor level. Once I created a floor at the first floor level, I was no longer able to see the interior basement walls below, sounds perfect, right? After I completed the first floor level and moved on to the second floor level, upon creating a floor at the second level, I am still able to see the first floor walls below! I have tried recreating the floor, verifying the top constraints of the first floor wall, but I am having zero luck.
Short of selecting every first floor wall below and hiding it in that view, does anyone know of some setting that I can tweak to hide walls below?
Many thanks in advance, I'm at my wits end!
OK, so after I finally resorted to posting in this forum, I solved the problem. On the floor plan properties, I had "first floor" level set as an underlay...Duh.
13 Posts No Rating |
thanks; i had same issue these days and solved the problem with this thread.
Thanx to this thread old but goldie....
I dude try view range in modifier make it all 0 amunt.i hope it will help
Structural walls in Architectural Model |
Fri, Aug 6, 2010 at 9:51:38 AM
HOw Do i HidE ThOse Lines ? |
Mon, Oct 30, 2006 at 9:03:36 PM
Hide insulation in MEP 2012 |
Wed, Sep 5, 2012 at 3:39:15 AM
Hide top of walls |
Tue, Apr 28, 2009 at 3:38:50 PM
Hide Isolate |
Fri, May 2, 2014 at 2:34:09 PM
Members: | 2102573 | Objects: | 23173 | Forum Posts: | 152290 | Job Listings: | 3 |
