98 Users Online (97 Members):
Forums >> Revit Building >> Technical Support >> Disapearing Floors
Anyone experiencing that floors will just delete themselves? If so how do you stop this?
![5 Stars: 2 Votes](/images/stars_5.gif) |
When you move something that is attached to a floor I.E a wall, the move may cause to floor extrusion to become invalid and the floor will be deleted. I.E a line may become too short in the floor extrusion or lines may cross up. An error message should come up saying extrusion invalid delete instances?
I'm sure you could select a floor and think you have something else selected. I have done this also. I have deleted a floor in Vectorworks not knowing I had it selected. Tab through and make certain of what you have selected.
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
To avoid this issue. When you receive this message, cancel out of the command and try moving the element with disjoin ticked. This will remove associations.
Thank you
Disapearing Import file |
Tue, Dec 26, 2006 at 4:31:10 PM
Joining the Geometry of two floors |
Wed, May 14, 2008 at 5:46:12 AM
Draftng Lines disapearing below roof?!?! |
Fri, Feb 22, 2008 at 3:58:03 PM
Grouping Floors |
Mon, Aug 22, 2005 at 3:47:49 PM
Dead horse still kicking - walls and floors strategy |
Tue, Oct 2, 2007 at 1:36:25 PM
Members: | 2017134 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
