57 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> footing and piers
Mon, Jan 16, 2012 at 5:26:14 AM | footing and piers
ashy
Hi, I am having trouble creating ref levels, I have a footing on a ref level and can place on a topo and it will adjust to the height of my topo where ever i place it but am having trouble creating a pier that will sit on top of it and will adjust to the footings height with a upper ref level to go to the next level? Can any one help?, or does anyone have pier that i could download?.
Thanks Mark.
Tue, Jan 17, 2012 at 5:00:10 PM | footing and piers
mhans
3 Stars: 10 Votes
Have you tried aligning and locking? Create a top or bottom level for your pier (stub column) and lock it to that level.
Motto: "No Post left behind"
Tue, Jan 17, 2012 at 6:53:49 PM | footing and piers
ashy
THAT MEANS YOU HAVE TO ADJUST IT MANUALLY I WANT IT TO BE ABLE TO ADJUST AUTOMATICALLY. CAN THAT BE DONE ? AND HOW?
Tue, Jan 17, 2012 at 7:08:43 PM | footing and piers
mhans
3 Stars: 10 Votes
I don't seem to understand your situation. Let me try it again. You want all your piers to have  all their top level the same and your footing to adjust according to the topo. If this is what you want, you have to adjust each individual pier to the desired level or create a floor, then select all your pier (usually a column) and attached (attach/detach command) it to that floor and delete the floor if you dont need it.
Footings and Piers
Wed, Dec 17, 2008 at 11:58:24 AM
Continuous footings for the Piers
Mon, Sep 30, 2013 at 12:23:16 PM
foundation piers
Mon, Feb 18, 2008 at 5:36:11 PM
Brick Piers
Fri, Jul 8, 2011 at 3:14:27 PM
How can I show concrete piles/piers beyond in a section view
Tue, Sep 20, 2005 at 6:59:33 PM
Page generation time: 0.2341
