Forums >> General Discussion >> Wishlist >> Wall Ivy
1 Posts No Rating |
Some one needs to create IVY that is crawling up a wall. It should be plant type where you can see the wall material behind it. Even more beautiful, if it were parametric to adjust height and width of the IVY coverage.
sounds like you have outlined a nice task for yourself. be sure to share when you get it done.
Can you solve this with image (wall with ivy) as material?
Revit doesnt like that idea at all. materials are the way to go. its super easy to create and looks great.
THE TRICK TO THIS IS TO DOUBLE CLICK ON THE IMAGE IN THE MATERIAL EDITOR TO OPEN UP A WHOLE SET OF DIALOGUES, INCLUDING "CUTOUTS", WHICH, IF YOU REVERSE ENGINEER A CHAIN LINK FENCE MATERIAL, ALLOWS LIGHT TO PASS THROUGH A MATERIAL BASED ON WHAT IS BLACK ON YOUR IMAGE, E.G. YOU WILL NEED AN IMAGE AND ITS NEGATIVE (TO DEFINE NEGATIVE SPACE). YOU WILL NEED TO PUT YOUR MATERIAL (IVY) INTO PHOTOSHOP TO MAKE A NEGATIVE IMAGE OF YOUR MATERIAL AS THE CUTOUT. HERE'S ONE I DID
http://www.turbosquid.com/Search/Artists/Revitaoist |
In Nov 2008 "rossaftermath" post this: http://www.revitcity.com/forums.php?action=viewthread&thread_id=13901
Plant request - I am looking for some vines or ivy perhaps. |
Thu, Dec 3, 2009 at 10:08:26 AM
Does anyone have any suggestions for creating IVY? |
Wed, Oct 8, 2008 at 8:07:29 AM
Ivy Generator |
Sat, Apr 2, 2011 at 6:29:34 PM
ivy plant |
Tue, Jul 28, 2009 at 6:29:17 AM
ivy? |
Wed, May 5, 2010 at 11:02:35 AM
Members: | 2119202 | Objects: | 23205 | Forum Posts: | 152300 | Job Listings: | 3 |
