65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Origin Issues when Exporting to Navisworks
Fri, Jan 13, 2012 at 1:33:19 PM | Origin Issues when Exporting to Navisworks
cpatton
I have an architectural Revit model and a Structural Revit model.  They are linked together in the proper location in Revit.  When i open them individually in their own Revit files and export them as an .NWC file and then open them in Navisworks they import to two different locations like they have different origins.  Can anyone help with this issue?  Is there a setting in the Navisworks Export Settings that i may not have on or off.  It is currently set up with the default settings.
Thanks!
Fri, Jan 13, 2012 at 1:39:02 PM | Origin Issues when Exporting to Navisworks
mhans
3 Stars: 10 Votes
Under Manage tab, verify that both files have the same location, coordinates & position. It is not when you linked struc with arch files and match them on screen.
Motto: "No Post left behind"
Fri, Jan 13, 2012 at 1:50:09 PM | Origin Issues when Exporting to Navisworks
cpatton
Sorry if this is a basic question, i just haven't had to change origins before.  Their Location is the same.
How do i check the coordinates and the Position.  Both of their drop down menus don't have an options that pull up a screen to tell me the Coordinates or the Position.
Thank you.
Fri, Jan 13, 2012 at 2:03:15 PM | Origin Issues when Exporting to Navisworks
mhans
3 Stars: 10 Votes
Under Manage Tab, click coordinates then click Report Shared Coordinates. Compare the values you are getting when picking the same point on both the Arch & Struc models.
Revit to Navisworks
Wed, Jul 5, 2006 at 4:25:36 PM
Export Issue from revit to navisworks
Thu, Apr 15, 2010 at 9:14:19 AM
navisworks switchback
Wed, Apr 20, 2016 at 10:25:46 AM
Revit link not exporting to navisworks
Tue, Jul 14, 2009 at 4:47:51 AM
Exporting to Navisworks 2009
Thu, Mar 5, 2009 at 6:41:40 PM
Page generation time: 0.9886
