118 Users Online (117 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Referenced view
Fri, Jan 13, 2012 at 12:28:23 PM | Referenced view
rwelliot3
I have section tags that are referencing certian drafting views.  One group of tags is referencing the wrong view, is there a way to change the referenced view without creating a new section tag?  I have about 100 of them to change, it would be great if there was a easy fix.  Any help would be greatly appreciated.
Fri, Jan 13, 2012 at 12:37:10 PM | Referenced view
The only way would be to change the referenced drafting detail using copy paste.  Otherwise, you have to create new reference tags.  << This means edit the detail - swap them!
Edited on: Fri, Jan 13, 2012 at 12:37:47 PM
Fri, Jan 13, 2012 at 1:28:10 PM | Referenced view
rwelliot3
GENIUS!!  Thank you.  You saved me an hour at least!
Referenced views floating in space
Thu, Oct 22, 2015 at 2:43:49 PM
Note with a referenced view
Wed, Jun 29, 2011 at 1:32:53 PM
"Referenced From" Issue with Section Marks
Mon, Feb 6, 2012 at 2:55:02 PM
referenced sections
Wed, Apr 2, 2008 at 1:06:06 PM
export dwg with views not referenced
Thu, Apr 29, 2010 at 4:23:33 AM
Page generation time: 1.1349
