26 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Beam system demo
Does anyone know how to show pieces of a beam system as demolished in the new construction phase? It appears as if I can only demolish the whole system.
I'm still using Revit Architecture 2011. FYI.
![3 Stars: 10 Votes](/images/stars_3.gif) |
I guess, you draw 2 beams and join them together. Draw one in one phase and the other in another phase.
Motto: "No Post left behind" |
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
After a quick test it does appear that you CANNOT demo a beam within a beam system. Even using the TAB key to select the beam.
Even if you UnPin the beam  which allows some movement but unfortunately no demo).
You'll have to 'Remove Beam System' which basically explodes it into individual beams.
Then you can demo.
Thanks for your help. I thought as much.
Beam system height VS. Beam height error |
Fri, Jan 22, 2016 at 4:31:20 PM
Adding a beam system issue |
Sun, Jun 15, 2014 at 2:58:10 PM
Beam System Tag |
Fri, Aug 14, 2009 at 3:09:33 AM
Schdule of Beam System |
Tue, Jan 4, 2011 at 5:45:12 AM
beam system |
Thu, Oct 15, 2015 at 7:32:17 AM
Members: | 2017982 | Objects: | 22948 | Forum Posts: | 152215 | Job Listings: | 3 |
