117 Users Online (116 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Roads in a slope
Fri, Jan 13, 2012 at 11:33:48 AM | Roads in a slope
Passa
Hi! How do i create roads in/on a sloped topographie? the road should be 100mm into ground with kerbline & footpath. I can't find an offset option for a 'subregion' in 'massing & site tab'. the subregion is always on the surface of the topography.
A ' building pad' does draw the road 100mm offset into ground but I will never get the right slope of the terrain with 'slope arrow'.
Please could anyone help?
Fri, Jan 13, 2012 at 11:39:23 AM | Roads in a slope
mhans
3 Stars: 10 Votes
Use the floor option instead.
Motto: "No Post left behind"
Fri, Jan 13, 2012 at 11:58:32 AM | Roads in a slope
You need to edit the contours in your split surface to shown the new slope.  Just add enough points to create the curb and the slope to curb pavement.  Don't worry about modeling thickness of pavement/curb.  That's for details.
Fri, Jan 13, 2012 at 1:26:51 PM | Roads in a slope
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
below are a couple of alternate methods, Sweep blends, and Ramp
Fri, Jan 13, 2012 at 1:41:58 PM | Roads in a slope
mhans
3 Stars: 10 Votes
Nice mbsteve! Floor & Slab Edge works fine, too.
Fri, Jan 13, 2012 at 1:47:53 PM | Roads in a slope
Passa
Hi there, thank you for your response. i will try it.
Where are the roads?
Thu, Jul 17, 2008 at 2:13:41 PM
Roads
Mon, Apr 3, 2006 at 10:21:49 AM
revit terrain and roads
Wed, Jul 25, 2012 at 2:19:59 AM
How to create roads on terrain?
Thu, Sep 27, 2018 at 11:30:57 AM
How to make Roads in site?
Mon, May 31, 2010 at 4:29:43 AM
Page generation time: 1.6342
