74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Wall connections
Fri, Jan 13, 2012 at 10:54:52 AM | Wall connections
tmassey
tmassey Avatar
I have tried almost everything to clean up the wall types and still they intersect into my exterior walls. Any help would be appreciated. I have searched the forum for this and tried several methods with no luck.
  • Change Wall orientation (right click on wall) Change Wall orientation
  • If all the finish layers are inside the core boundary, the functions of the components of the wall are not clearly defined. Move outside of core boundary
  • turn off the allow join on the end of the double wythe wall and drag it to just touching the brick ( i don't want to do this.
  • edit this wall and somehow get the brick into the same category as the face brick.
Using Revit Architecture 2012
Fri, Jan 13, 2012 at 10:59:31 AM | Wall connections
Read this in your HELP: Applying a Function to a Layer of a Compound Structure  << This explains the rules you need to follow.
Wall Joins and Phasing
Mon, Aug 14, 2006 at 4:22:23 PM
Precast embed connections
Wed, Jul 30, 2008 at 11:22:14 AM
Revit 2018/2019 Steel Connections
Thu, May 10, 2018 at 8:05:18 AM
Problem with wall connections
Thu, May 5, 2011 at 4:12:36 PM
Vertical and horizontal bracing connections
Mon, Jun 24, 2013 at 7:18:39 AM
Page generation time: 1.1234
