23 Users Online (22 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Removing Segments from a wall sweep
Thu, Jan 12, 2012 at 9:08:28 AM | Removing Segments from a wall sweep
rwelliot3
When I place a wall sweep on a wall with penetrations, multiple segments are created.  Is there a way to eleminate/delete some segments with out deleteing the whole?  Now, my work around is to drag them over to look like one single segment, but that creates duplication and looks messy.  Any tips would be appreciated.
Thu, Jan 12, 2012 at 9:14:14 AM | Removing Segments from a wall sweep
It sounds like you have already learned the only solution.
Each sweep has two ends - one at each true end.  Openings that break the sweep do not really create seperate segments.  Your solution is to drag one end back across the openings until you have only one segment.  Then add another sweep along the same line and drag both ends until you have another segment.  And continue.....
Thu, Jan 12, 2012 at 4:38:18 PM | Removing Segments from a wall sweep
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Maybe just do it an an in-place family instead of the sweep tool ?
Fri, Jan 13, 2012 at 12:29:25 PM | Removing Segments from a wall sweep
rwelliot3
Thanks, I'll try that.  I appreciate the help.
Fri, Jan 13, 2012 at 2:39:10 PM | Removing Segments from a wall sweep
mhans
3 Stars: 10 Votes
Can you share what happened on your query?
Motto: "No Post left behind"
Sat, Jan 14, 2012 at 7:05:18 PM | Removing Segments from a wall sweep
rwelliot3
Sorry for the delay, I haven't been in front of a computer in a while.  I created a wall based family and used that instead of the sweep, it was a nice work around.
Mon, Jan 16, 2012 at 11:25:12 AM | Removing Segments from a wall sweep
mhans
3 Stars: 10 Votes
Thanks for sharing.
Removing multiple curtain wall grid segments
Mon, Jun 13, 2016 at 9:53:15 PM
Curtain Grid Removing Segments
Mon, Jul 2, 2007 at 1:05:12 PM
Removing Wall Sweep or Reveal
Thu, Apr 17, 2014 at 2:46:46 PM
Wall sweep won't trim
Tue, Apr 25, 2017 at 2:07:17 PM
Removing individual vindowsegments from a curtainwall?
Wed, Apr 22, 2009 at 8:20:08 AM
Page generation time: 3.9928
